BizBit
Jan 19, 2023Aspirant
Nighthawk R7000 reliable problems
Hi, I have had a NetGear Nighthawk R7000 since 2016, it have worked well! But now there is a couple of problems. It started with all devices losing connection to the router from time to time. I ...
BizBit
Yes, sorry, the fiber modem is connected directly to the router(Nighthawk R7000) and then the router is connected to the larger switch.
I will try to factory reset and update the Nighthawk R7000 and see if that helps.
Kitsap
Jan 19, 2023Master
BizBit wrote:Yes, sorry, the fiber modem is connected directly to the router(Nighthawk R7000) and then the router is connected to the larger switch.
Be sure and do a manual firmware update.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
It is still possible your fiber modem is a combination modem/router device.
