deragon
Nov 28, 2023Aspirant
Nighthawk R7000 Saved/Check Password try again error
My phone (Pixel 8 Pro) all of a sudden won't connect to my Nighthawk R7000 router. Anyone know what is causing this? I have forgot the network and tried to reconnect, NG. I have reset the router, NG....
Nov 28, 2023Guru - Experienced User
Pixel FW updated recentlly?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
What FW is loaded on the R7000?
deragon
Nov 29, 2023Aspirant
I am running the latest update from Google on the Pixel, updated 11/06. I made sure the MAC randomizer is off and just set to phone. Still nothing. I checked for updates on the router last night when I was connected and it said no update available so I must be on the latest.
- FURRYe38Nov 30, 2023Guru - Experienced User
Do other devices connect to the router?
- deragonNov 30, 2023AspirantYes, there are multiple other devices connected. Tvs, smart speakers, a computer. Probably 10 devices? Girlfriends pixel 7 pro connects no problem.
Probably something to contact Google about and let them know and see if they can help you out.
