HikingPlane0's avatar
HikingPlane0
Nighthawk r7000 slow wifi and even slower ethernet
Hello, I recently bought gigabit ethernet for comcast xfinity, and my motorola mb8600 pulls a steady 500 mbps download when running a speed test directly connected to it, but its a single port modem....
  • plemans's avatar
    Apr 06, 2020
    HikingPlane0 wrote:
    I just ran some speed test to get some exact results so here it is:
    PC ethernet to modem:
    Fast.com- 430
    Speedtest.com- 189
    xfinity.com- 507
    Speedtest app- 130
    PC ethernet to router:
    Fast.com-220
    Speedtest.com-185
    xfinity.com-530
    Speedtest app-140
    iPhone wifi-
    speedtest app- 330
    Nighthawk app- 376
    fast.com-360
    A lot of speed testing depends on what site you're testing with. When you get >250mbps speeds, a lot of the servers need to be able to handle it. You've put that you're hitting 500mbps directly connected to the modem. You're hitting full speed on xfinity which is a good sign as it tends to be able to saturate the full speeds.
