ezone
Aug 02, 2018Star
Nighthawk R7000 Slow WiFi speed
After the latest FW update (V1.0.9.34_10.2.36) my wifi starts jumping upp and down . I'v got 2 of R7000 and one is acting as AP.
I uppgraded FW then factory reset still same issue on both R7000 . T...
- Aug 02, 2018
Hello ezone
I have escalated this issue to our engineers and our support team would like to work with you. I have sent you a PM.
DarrenM
JohnWill
Aug 16, 2018Tutor
Same issue. Tired of messing around with the settings. Terrible speeds, cannot get better than 20 mbps wireless. V1.0.9.34_10.2.36. Using wifi scanner I've locked router to a quiet channel but have seen in the same scanner the 2.4 GHz network spiking every few seconds. Unusable
