ezone
Aug 02, 2018Star
Nighthawk R7000 Slow WiFi speed
After the latest FW update (V1.0.9.34_10.2.36) my wifi starts jumping upp and down . I'v got 2 of R7000 and one is acting as AP.
I uppgraded FW then factory reset still same issue on both R7000 . T...
- Aug 02, 2018
Hello ezone
I have escalated this issue to our engineers and our support team would like to work with you. I have sent you a PM.
DarrenM
Derickm
Aug 16, 2018Tutor
I read the "solved" description for the R7000 and 5G radio that turns on and off. I have two R7000's (both early production and later), neither keeps the radion running.
The up/down time varies, but the cycle isn't longer than 3 minutes. I get connected, and then it is down again for a few seconds to minutes.
I can watch the radio come up then down using a WiFi Analyzer app on my tablet or phone.
Is there older firmware that never had this problem? Old and works is better than new and fails.
Thanks, Derick
aabshire
Aug 16, 2018Apprentice
After going through this before and now again with another update, I am about ready to move to an alternate frimware.
- ezoneAug 16, 2018StarNot solved yet and haven't head from them
- frataplawiAug 23, 2018Aspirant
Same problem Here
Any news ?
Wifi very slow and the whole router seems to be slowing down after a few minutes since upgrading to V1.0.9.34_10.2.36.
Franck
- PunksonicAug 23, 2018TutorHas this been fixed yet?! My router is so useless right now. I’m so close to buying a different one. Is there a fix?!? I still can’t believe that I’m paying for 100 Mbps and getting 9 Mbps on WiFi. Please please please help!!!
