ezone
Aug 02, 2018Star
Nighthawk R7000 Slow WiFi speed
After the latest FW update (V1.0.9.34_10.2.36) my wifi starts jumping upp and down . I'v got 2 of R7000 and one is acting as AP.
I uppgraded FW then factory reset still same issue on both R7000 . T...
- Aug 02, 2018
Hello ezone
I have escalated this issue to our engineers and our support team would like to work with you. I have sent you a PM.
DarrenM
DASBUSEN
Aug 29, 2018Initiate
Experiencing this same exact issue. Also the "Solved" comment isn't a solution.
Also I'd like to note ive tried to downgrade to V1.0.9.6_1.2.19 and my router tells me no..... *AWESOME*
:smileyfrustrated:
Franchester
Aug 29, 2018Tutor
Does Netgear even look at these posts? I only get responses from other users with the same issue. I'm starting to think the fix is to throw this POS in the trash.
