ezone
Aug 02, 2018Star
Nighthawk R7000 Slow WiFi speed
After the latest FW update (V1.0.9.34_10.2.36) my wifi starts jumping upp and down . I'v got 2 of R7000 and one is acting as AP.
I uppgraded FW then factory reset still same issue on both R7000 . T...
- Aug 02, 2018
Hello ezone
I have escalated this issue to our engineers and our support team would like to work with you. I have sent you a PM.
DarrenM
Punksonic
Oct 05, 2018Tutor
I felt the same way and after restarting it, getting new cables, and playing around with the settings, I finally bit the bullet and went out and bought their main competitors router. Let me tell you, the quality is 100 percent better and I have had stable and fast internet ever since. It is sad because I have owned multiple Netgear routers in the last 20 years.
Franchester
Oct 05, 2018Tutor
Unfortunately. I agree. The only true fix is to throw the night hawk in the garbage and purchase a router from a different company. I too have only bought Netgear products in the past but not anymore. I'll never buy a Netgear device again.
