ezone
Aug 02, 2018Star
Nighthawk R7000 Slow WiFi speed
After the latest FW update (V1.0.9.34_10.2.36) my wifi starts jumping upp and down . I'v got 2 of R7000 and one is acting as AP.
I uppgraded FW then factory reset still same issue on both R7000 . T...
- Aug 02, 2018
Hello ezone
I have escalated this issue to our engineers and our support team would like to work with you. I have sent you a PM.
DarrenM
ezone
Oct 05, 2018Star
Well that sorry hasen't help me haven't had a working Wi-Fi since i reported this issue. And it seems that it aint solved yet.
Sad to say stuff like this gives the brand bad and unwanted pr. And your not compensating your customers makes it even look worse.
The lack of help from you forced me to get routers to maintain my Wi-Fi.. Not fun to put 300 dollars to get a working Wi-Fi cause a sofware upgrade makes it un usebel.
rreszler
Oct 18, 2018Aspirant
I am having the same issue as soon as I updated to the latest by wifi went from awesome to unusable and I have tried everything. I update every time and have notfications turned on so that I do so right away and it just started as soon as I went to V1.0.9.42_10.2.44
