ezone
Aug 02, 2018Star
Nighthawk R7000 Slow WiFi speed
After the latest FW update (V1.0.9.34_10.2.36) my wifi starts jumping upp and down . I'v got 2 of R7000 and one is acting as AP.
I uppgraded FW then factory reset still same issue on both R7000 . T...
- Aug 02, 2018
Hello ezone
I have escalated this issue to our engineers and our support team would like to work with you. I have sent you a PM.
DarrenM
JohnWill
Nov 01, 2018Tutor
Well I guess they mean the new one - V1.0.9.42_10.2.44
Saw the post and did a speed test on the 2.4GHz and could only get 40Mbps a couple of metres away from the router, updated and repeated test and it was around 110Mbps. I've now re-enabled the 5GHz radio which I'd disabled as it was hopeless - speed test is giving me 217Mbps (wired is around 220Mbps download) so hopefully it's sorted now.
As long as I'm getting decent wireless speeds now I'll be very careful about routinely updating to the latest firmware again - I was ready to reolace this router with an alternative to solve the issue.
ezone
Nov 01, 2018Star
Yes thats the version im running but ill se if it is still stable after running it for some weeks.
