ezone
Aug 02, 2018Star
Nighthawk R7000 Slow WiFi speed
After the latest FW update (V1.0.9.34_10.2.36) my wifi starts jumping upp and down . I'v got 2 of R7000 and one is acting as AP.
I uppgraded FW then factory reset still same issue on both R7000 . T...
- Aug 02, 2018
Hello ezone
I have escalated this issue to our engineers and our support team would like to work with you. I have sent you a PM.
DarrenM
ramzusa
Dec 01, 2018Aspirant
I am having the same issue with V1.0.9.42_10.2.44. Before the updated I was getting 400 mbps, now getting between 20 and 30 mbps. This is both for wired and wireless.
When I am directly connected to ISP I am consistently getting 400 mbps.
Has anyone found a solution? Is there a stable FW that I can downgrade too that will resolve this issue?
t18c97
Dec 01, 2018Tutor
Checked this week and there is a V1.0.9.58_10.2.58 now showing up. Did the update and my speeds are back and the VPN appears to be also working again.
- ramzusaDec 01, 2018Aspirant
Thanks for the suggestion.
I updated FW to V1.0.9.58_10.2.58, factory reset and then reconfigured.
However, this did not resolve my issue. DL speeds are between 20 and 30 mbps (wired and wireless).
When connected directly to ISP modem, am getting 400 mbps.
- t18c97Dec 01, 2018Tutor
Sorry it’s not working for you. I have 200Mbps service and getting that or a bit higher on the 5G side.
- Customer-XDec 01, 2018Star
I have solved this problem. I bought a TP-Link and donated my R7000 to a homeless center.
