ddister_1's avatar
ddister_1
Initiate
Sep 04, 2018
Nighthawk R7000 Slow WiFi speed
Wifi slowness issues. I have firmware V1.0.9.34_10.2.36,  which I just updated recently. Any idea what the fix is?
  • ddister_1's avatar
    ddister_1
    Sep 06, 2018
    Shadowsports....I downloaded V1.0.9.34_10.2.36 to my laptop then uploaded/installed chk file through the router Advanced>Admin>Router Update>Browse to file downloaded to laptop file location. Which was the same FM I had already installed but I did that through the Geni updated within the router GUI. I have not done anything else. I had done a factory reset but that was before I downloaed the FM and installed it. So far I have not been disconnected like I was before. I will update my notes if wifi slowness has improved. Thanks shawdowsports for your input in helping me with my issue.
