Chocolate_Atom
May 23, 2019Tutor
Nighthawk R7000 Slow wired speeds Verizon Fios
Hello, having issues with wired download speeds with my R7000 Nighthawk on Verizon Fios. I removed the Fios gateway, and have the Nighthawk router connected to the WAN from the ONT. I have a Actionte...
- May 24, 2019
I did a reset of the ONT. No dice, still had slow speeds. So I did a factory reset on the Nighthawk. After comgin back up, I was going through all the settings and lo and behold, the IPv6 setting was disabled. I set it to auto-detect and after updating (showing as 6to4 tunnel), I am now getting close to gigabit d/l and u/l. No idea how or why it was disabled, but that was the problem.
Chocolate_Atom
May 23, 2019Tutor
Some more info on my setup:
QoS is turned off, WMM is on.
Firmware: V1.0.9.64_10.2.64
Connected on Port 4: Status 1000M/Full
Onboard ethernet adapter: Intel I211 Gigabit Status: 1.0Gbps Full Duplex (EEE Active)
- plemansMay 23, 2019Guru - Experienced User
the .64 firmware for the R7000 has been having plenty of issues if you search the forums. Best results with it was for people to do a reset before firmware upgrade and after the upgrade.
did it ever work at full speeds for you?
If it did but hasn't since the update, I'd recommend downgrading a version or 2 to see if that helps. Make sure to do it over a hardwired connection and do a factory reset afterward. The .42 firmware has been the one getting the most solid reviews for the R7000
- Chocolate_AtomMay 23, 2019TutorHey, thanks for the reply. I did read about the new firmware. I had my Nighthawk connected to the Fios gateway as an access point. Wanted to use the Nighthawk to handle the wifi. Hard wired my comp to the Nighthawk and had same issues as now. Very slow. Hard wired into the Fios gateway and was getting over 750 Mbps. Was using an older firmware when it was setup.
which version of firmware? The .60 and .62 rate about the same.
