stuntboots
Apr 20, 2016Tutor
Nighthawk R7000 Slow/Stuttering Video Streaming
Hi there! Basically, video streaming is extremely poor in my home. Both wired and wirelessly on laptops, desktops, iPhones, iPads, a Nexus and Apple TVs. (Haven't tested the mobiles wired, but th...
- Apr 22, 2016
Actually it didn't seem to fix it for my Apple TV. Still got constant buffering on HBO Now. However I have since turned off WMM, and that seems to have me streaming perfectly fine. Takes a second to start up after playing or rewinding/fast forwarding then playing, but once it's going, no pauses. Hopefully it's not just coincidence!
IrvSp
Apr 20, 2016Master
stuntboots wrote:Hi there!
Basically, video streaming is extremely poor in my home. Both wired and wirelessly on laptops, desktops, iPhones, iPads, a Nexus and Apple TVs. (Haven't tested the mobiles wired, but the computers and ATVs I have.) However if I do a speed test at http://www.speedtest.net, I get anywhere between 85Mbps and 95Mbps.
I'm on cable internet, and have a Netgear Nighthawk R7000 with firmware V1.0.5.48_1.1.79 (It tells me an upgrade is available, but when I click it it says I'm up to date, I checked the website and it seems the latest on there is older?) connected to my provider's provided modem in bridge mode. I also have the QoS enabled downstream, but have tried disabling it and still get the same issue.
The whole internet runs perfectly fast, but when streaming any kind of video, whether it's from YouTube, Netflix, Hulu or websites who host their own video streaming, like Steam or Polygon, videos will constantly pause to buffer sometimes for ~1-2 minutes, if they resume at all. Sometimes resetting the modem/router or device (like the Apple TV) will get it going again for awhile, but it's definitely not always a reliable fix.
Any help is greatly appreciated! Happy to try any kind of diagnosing, obviously!
First, I have NOT used the F/W release you are using, that was and old beta and had problems.
I have never had QoS on, just the WMM is enabled on the QoS tab.
I stream NetFix, Amazon Prime, on a Samsung Smart TV (FireTV stick on another TV), and iPad's. Also on iPad's I stream many apps including Showtime, HBO Go, and many others. No problems at all.
I was on V1.0.4.30 and now on the last Beta (https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-60/m-p/1070857#M30302). All works fine. The Beta, 1.0.5.60 replaced all the releases after V1.0.4.30 which is the LAST official one. The one you are using and one after it were pulled for problems.
First I'd disable QoS and make sure WMM is enabled. Test again. If not drop back to either of the 2 above releases and re-test. Works for m.
- stuntbootsApr 20, 2016Tutor
Hey, thanks IrvSp!
I'll try out that new firmware, my current version having been pulled for errors doesn't indicate anything good! Hehe. I'll try updating to the latest beta and disabling QoS while enabling WMM and report back!
