Bemanmac
Aug 05, 2016Aspirant
Nighthawk R7000 stopped working after 4 months
My Nighthawk AC1900 WiFi model R5700 stopped working suddenly after only four months. I went through all of the troubleshooting steps in the manual, but I still get the Amber lights that according to ...
- Aug 13, 2016Ya'll missed the point on the 4 year issue- that was the modem being replaced, but it lasted 4 years. Commenting on it is totally not helpful. What was helpful was taking to my son - an IT director for a school system in MN. He diagnosed and repaired it - working fine...to the first two answers, thanks!
Bemanmac
Aug 13, 2016Aspirant
Retired_Member
Aug 13, 2016Please share the fix..Taking to son is No Solution.
- BemanmacAug 13, 2016Aspirant
On the Nighthawk Routers, if you do a factory reset more than just once in say, less than an hour, it confuses the router - essentially, it is trying to reset itself and in the middle of the reset, you interrupt the process with another factory reset and "confuse" the OS and once the router stops working - no matter what you try (ie. re-login, changing browser settings - pretty much anything in the troubleshooting discussions, it won't work. I cannot tell you the intricate details of the exact steps he took ( I just happen to be fortunate to have him, perhaps there is a local "techie" that doesn't charge too much that could get the same results), but when I walked in his office he had the Genie page up and all was well. He uses only Netgear wireless equipment in his entire school system, he says they are, in hs experience the most consistantly dependable. The biggest take-away is that if you push that factory reset button, give the router a good hour (err on the side of caution) before you attempt any "fixes". This was "my bad", because when a person gets frustrated, you just start pressing buttons (common, according to son) So patience with the factory reset.
- Retired_MemberAug 13, 2016
What I have found is after a reset to defaults the PC needs to be rebooted to connect to it before you login into router setup. I will say this was not always the case and changed about 2 years.
I finally dumped NG FW and wished I had years ago.
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
- dpouSep 02, 2016Aspirant
Same problem!!! I am angry that after only 4 months, this unit stopped working out of the blue. I was watching the Olympics - suddenly nothing. I missed the closing ceremonies too. I called Netgear and they wanted $50 to answer my question!!! I had never called their customer service and was appalled they wanted so much money to find out why their product stopped working after owning it for such a short time. Customers do not get even 1 service call???????? I will throw this unit in the trash and NEVER EVER BUY NETGEAR MERCHANDISE AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!
