RW_MP
May 15, 2017Aspirant
Nighthawk R7000 Updated to Firmware Version: V1.0.8.34
My Nighthawk R7000 AC1900 Dual Band WIFI just updated to Firmware Version: V1.0.8.34_1.2.15. I used the process Router Update, Check for new version from the Internet. Where can I find the release...
- May 16, 2017
Information from ElaineM:
"We are working to rollout a new firmware with additional features for existing customers in a phased manner. Once the rollout is completed, we will make the firmware available on support site for a wider audience."
shamarin
May 15, 2017Virtuoso
Strange, i have no update at all. Still only 1.0.7.12 is available.
- droyderMay 16, 2017Aspirant
Make a backup copy of your current settings (.cfg file) under Advanced > Backup Settings and then do a hard reset of your router. Once it's been reset and you're connected via ethernet, it should cue the FW upgrade option when you're doing the initial setup again.
Then just upload that config file and your previous settings will be back.
- shamarinMay 16, 2017Virtuoso
You wrote to me? I checked firmware updates and there is no updates on my router. Strange.
shamarin wrote:You wrote to me? I checked firmware updates and there is no updates on my router. Strange.
Yes, I'm saying that if you really want to upgrade your FW now, try what I just recommended.
I didn't even know there was a new FW available today, but this morning I just so happened to do a hard reset of my modem and R7000 (by purshing reset pin on the back). And once everything was back on and I connected to the router via ethernet, Genie alterted me there was a new FW and so I did the update. So following those same steps will likely cue the FW update for you too should you like to act now.
