RW_MP
May 15, 2017Aspirant
Nighthawk R7000 Updated to Firmware Version: V1.0.8.34
My Nighthawk R7000 AC1900 Dual Band WIFI just updated to Firmware Version: V1.0.8.34_1.2.15. I used the process Router Update, Check for new version from the Internet. Where can I find the release...
- May 16, 2017
Information from ElaineM:
"We are working to rollout a new firmware with additional features for existing customers in a phased manner. Once the rollout is completed, we will make the firmware available on support site for a wider audience."
shamarin
May 15, 2017Virtuoso
Strange, i have no update at all. Still only 1.0.7.12 is available.
droyder
May 16, 2017Aspirant
Make a backup copy of your current settings (.cfg file) under Advanced > Backup Settings and then do a hard reset of your router. Once it's been reset and you're connected via ethernet, it should cue the FW upgrade option when you're doing the initial setup again.
Then just upload that config file and your previous settings will be back.
