RW_MP
May 15, 2017Aspirant
Nighthawk R7000 Updated to Firmware Version: V1.0.8.34
My Nighthawk R7000 AC1900 Dual Band WIFI just updated to Firmware Version: V1.0.8.34_1.2.15. I used the process Router Update, Check for new version from the Internet. Where can I find the release...
- May 16, 2017
Information from ElaineM:
"We are working to rollout a new firmware with additional features for existing customers in a phased manner. Once the rollout is completed, we will make the firmware available on support site for a wider audience."
May 20, 2017Guru - Experienced User
Did you do a factory reset before and after upgrading FW then set up from scratch using IE11 or FF? Besure to chear all broswer caches before and after loading the FW file.
If this still fails, you could try OpenRouter FW to see if this helps any.
FrenchFrog wrote:This firmware 1.0.8.34_1.2.15 is crap. I install it on my Nighthawk R7000 and port formwarding is breaked. QoS is malfunctionning. I have to use tftp for rollup to 1.0.7. Apoligize for my bad english please.
FrenchFrog
May 20, 2017Aspirant
Factory reset, clearing browser's cache, etc... After two times trying install this firmware, port forwarding is breaked. I don't install this firmware anymore. My browser is Google Chrome. I reinstall firmware 1.0.7.12 and all is ok. Fortunately, this firmware is not on the support's site.
- FURRYe38May 20, 2017Guru - Experienced User
Probably keep what you have that works loaded. Try OpenRouter FW at some point. Good Luck.
