RW_MP
May 15, 2017Aspirant
Nighthawk R7000 Updated to Firmware Version: V1.0.8.34
My Nighthawk R7000 AC1900 Dual Band WIFI just updated to Firmware Version: V1.0.8.34_1.2.15. I used the process Router Update, Check for new version from the Internet. Where can I find the release...
- May 16, 2017
Information from ElaineM:
"We are working to rollout a new firmware with additional features for existing customers in a phased manner. Once the rollout is completed, we will make the firmware available on support site for a wider audience."
Retired_Member
May 20, 2017Something must have happened, my port forwarding pieces are working with this update along with the QOS...maybe not the same but advice from the mentor is spot on, good luck.
May 20, 2017Guru - Experienced User
Maybe you can help the user with his settings to see if anything sticks out.
