RW_MP
May 15, 2017Aspirant
Nighthawk R7000 Updated to Firmware Version: V1.0.8.34
My Nighthawk R7000 AC1900 Dual Band WIFI just updated to Firmware Version: V1.0.8.34_1.2.15. I used the process Router Update, Check for new version from the Internet. Where can I find the release...
- May 16, 2017
Information from ElaineM:
"We are working to rollout a new firmware with additional features for existing customers in a phased manner. Once the rollout is completed, we will make the firmware available on support site for a wider audience."
LWD
May 22, 2017Aspirant
I recently updated my router firmware to V1.0.8.34_1.2.15 & I received an error after the download was complete. My router status indicates I have the new firmware loaded however, since then, my download speeds have dropped by 2/3 which now is about the same as my upload speeds. How do you reload the latest firmware? Please help, thanks
michaelkenward
May 22, 2017Guru - Experienced User
Did you "factory reset"? (See above.)
