RW_MP
May 15, 2017Aspirant
Nighthawk R7000 Updated to Firmware Version: V1.0.8.34
My Nighthawk R7000 AC1900 Dual Band WIFI just updated to Firmware Version: V1.0.8.34_1.2.15. I used the process Router Update, Check for new version from the Internet. Where can I find the release...
- May 16, 2017
Information from ElaineM:
"We are working to rollout a new firmware with additional features for existing customers in a phased manner. Once the rollout is completed, we will make the firmware available on support site for a wider audience."
Retired_Member
May 20, 2017Something must have happened, my port forwarding pieces are working with this update along with the QOS...maybe not the same but advice from the mentor is spot on, good luck.
ElaineM
May 26, 2017NETGEAR Employee Retired
Neu318 Did you try factory resetting the unit?
- gxcareMay 29, 2017Aspirant
Hi Elaine,
I really appreciate your support, but you should let your designers understand that resetting the unit after an upgrate should not be the normal way of handling these situations. The simple reason is that if some wrong setting is propagated from an old official release to a new one, it is design fault of Netgear which causes all of us to lose a lot of time to reconfigure our networks. You are actually avoiding design/test costs, moving the cost on your customers, which at the end will not be happy and remember this the next time they will buy a router...
Giuseppe
Customer
- avtellaMay 29, 2017Prodigy
Not every update requires it but some updates have major changes which require a complete reset, unless you dont want any major changes or improvements. Even on an iPhone or Android there are times where you are better off resetting due to issues post upgrade.
- Neu318May 29, 2017Aspirant
Elaine, I did the factory reset and my nest thermostat still kept disconnecting. I have since reverted to the previous firmware and it is working fine.
