RW_MP
May 15, 2017Aspirant
Nighthawk R7000 Updated to Firmware Version: V1.0.8.34
My Nighthawk R7000 AC1900 Dual Band WIFI just updated to Firmware Version: V1.0.8.34_1.2.15. I used the process Router Update, Check for new version from the Internet. Where can I find the release...
- May 16, 2017
Information from ElaineM:
"We are working to rollout a new firmware with additional features for existing customers in a phased manner. Once the rollout is completed, we will make the firmware available on support site for a wider audience."
kfh777
Jun 29, 2017Aspirant
My R7000 with 1.0.8.34 installed will not enable the 5Ghz channel. The check mark is there but greyed out as is the SSID which only states NetGear23 not NetGear23 5G as it did with earlier versions of the software. Will your new release fix that?
michaelkenward
Jun 30, 2017Guru - Experienced User
Where are you?
Firmware Version 1.0.8.34 is for North America Only.
If you are in North America, check that the router is set for the correct region.
By the way, you have joined in on an older discussion so there's a chance that the official support team will be too busy following new stuff to find your message. It is usually better to start your own fresh discussion if you want their attention.
- kfh777Jun 30, 2017Aspirant
Yes. I'm in North America. I'll try new posting. So far the best community advice is to revert to an earlier version than 1.0.8.34
Thank you.
- JamesGLJul 03, 2017NETGEAR Employee Retired
Hi All,
Try to reset the router to factory default after the update and manually reconfigure it.
- michaelkenwardJul 03, 2017Guru - Experienced User
JamesGL wrote:Hi All,
There are people who visit this forum who seem to think that a factory reset is akin to witchcraft. They are so averse to the idea that they won't even try it, no matter that it is a reversible process if you backup your savings and retain the option of reverting to older firmware. They would rather reverse engineer their devices and rewrite its internal software.
It might help if someone explained why a factory reset is appropriate. I'll start with my own theory.
As I understand it, the firmware is only a part of the device's internal memory. That memory also holds settings and instructions that come from the configuration that people have set up. Some of those settings may not work with the new firmware. So it helps to start from scratch with a clean memory. Then the settings can write new data into the device's memory that are compatible with the new firmware.
If this is not a legitimate explanation of what is going on, perhaps someone could put me right.
