Samlinxia's avatar
Samlinxia
Follower
Jun 07, 2020
Nighthawk R7000 USB drive format exFAT not recognized
My USB drive format is exFAT and is not being recognized by the ReadyShare USB drives.  Is there any solutions to that other than reformating to NTFS?  Do you have any plan to support exFAT format si...
  • microchip8's avatar
    Jun 07, 2020
    There is no support for exFAT and most likely never will be. The router runs an old kernel that needs heavy patching to support exFAT. Unlikely to be done
