stepqueen
Jan 12, 2016Aspirant
Nighthawk R7000 WAN connection instability
After updating the R7000 to the latest firmware (V1.0.06.28_1.1.83) I am experiencing flakey connectivity outside the home network on WAN. WiFi access is fine. Using WAN I am forced to do stunts like...
- Jan 13, 2016
A reboot is not the same thing as a reset. You need to do a reset.
stepqueen
Thank You LeeH. I did do a reboot from the Router admin interface but will try from the router itself. I think I may have solved it another way by just assigning an IP to specific machines.
