mikewest's avatar
mikewest
Nighthawk R7000, WEMO Switch problem
Have Nighthawk AC1900, Model R7000 Netgear92. About 6 years old. Running mostly Apple devices. Have 4 Belk WEMO switches that work fine. Trying to add a 5th and 6th but software won't let me log into...
  • mikewest's avatar
    mikewest
    Oct 04, 2017
    Thank you Antinode for giving me confidence that there must be a way to solve the problem.
    I have about 15 devices running through the Nighthawk unit.
    I again plugged one of the new Belkin mini switches into the wall (the one I tried to install yesterday) and tried to find it in the WEMO app on my iPhone, was not there. Went to Settings on iPhone and changed from 2G to 5G (apparently it was changed during the dozens of times I tried to install it yesterday). Then, went to the WEMO app and it ......MAGICALLY...... appeared. I have no idea why. Was then able to add the 6th WEMO mini switch and all are working just fine. I can run the iPhone of either the 2G or the 5G network on the Nighthawk router and everything seems to work on both networks.
