lekhanani
Apr 10, 2023Follower
Nighthawk R7000 WiFi questions (SSID naming best practice)
It appears to me that you cannot put spaces in your SSID. I've never seen that before. Is there a way around that? Also, is it best practice to give your 2.5GHz and 5GHz bands the same SSID or shou...
Apr 10, 2023Guru - Experienced User
Its not usually the router that has issues with those but some "smart" devices that I've seen.
there was a couple version of roku's firmware that had issues and again, a random smart device we see on here once in a while.
but most devices should be fine with it.
