Treebeard's avatar
Treebeard
Nighthawk R7000 WiFi
This router is about 6 months old but has been given me grief two or three times a day for the past few weeks.   Wireless devices show that they are connected to the router with a strong signal and i...
  • VE6CGX's avatar
    VE6CGX
    May 25, 2016
    Of cocurse. I always manually down load the f/w file, then do the upgrade/downgrade. I don't let the router do it. Before starting the process reset the router >> finish f/w >> another reset >> configure the router(I don't even use old saved configuration file in this case).
