Treebeard
May 24, 2016Aspirant
Nighthawk R7000 WiFi
This router is about 6 months old but has been given me grief two or three times a day for the past few weeks. Wireless devices show that they are connected to the router with a strong signal and i...
- May 25, 2016
Of cocurse. I always manually down load the f/w file, then do the upgrade/downgrade. I don't let the router do it. Before starting the process reset the router >> finish f/w >> another reset >> configure the router(I don't even use old saved configuration file in this case).
Treebeard
May 25, 2016Aspirant
Yes, you are right but what's done is done.
From what I have read since posting this question it appears doing a hard reset does not change the installed firmware. However older versions of firmware are available for download from Netgear support. Is it possible and "safe" to downgrade? If so, what is the recommended version?
VE6CGX
May 25, 2016Master
