curiousbob
Aug 30, 2018Aspirant
Nighthawk R7000 WILL power light illuminate with power supply plugged in and route button turned off
I live in US but router is in Mexico. Neighbor with access said no LED lights are visible on. My question: if the power supply is plugged in to a viable outlet and the on/off button is not pushed or ...
- Aug 30, 2018
if on/off button is set to off and power is connected to router, no lights will be visible.
also keep in mind that the user can disable the lights (except power LED) using the firmware GUI
microchip8
Aug 30, 2018Master
curiousbob
Thanks that is exactly the answer needed.
