jazzchamp
Jun 03, 2019Tutor
Nighthawk R7000 wireless keeps disconnecting wireless. Wired is fine
I've had this router for a while and it's been solid, but in the past two weeks, the wireless connection drops while the Ethernet connections attached to the router are fine. Rebooting the router typ...
- Jun 03, 2019
> [...] I have tried downgrading the firmware, [...]
To what?
> [...] currently at the latest version V1.0.9.64_10.2.64.
"Latest" and "best" are spelled differently for a reason. A quick
search of the forum should find any number of suggestions to try going
back to the ".42" firmware.Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
Many wireless-network problems are possible. You might, for example,
try changing the radio channels.
antinode
Jun 03, 2019Guru
To what?
instructions.
