fdelmo10
Apr 21, 2021Tutor
Nighthawk r7000 wireless will not turn on light are off even after rest
I replaced my r7000 with an orbi 6 months ago. I wanted to connect my r7000 in my son's apartment. I can not get the wireless to turn on even after resting muliple time . Any suggestions.
This tells us too little about your network.
What are you doing and where does it go wrong?
What is the modem in front of this router, if there is one?
What do the LEDs on the router look like?
- fdelmo10Tutor
We tried to hook it up to spectrum modem. The only light that came on was the power light and the port light we had the ethernet cable pluged into it. Using the set up www.routerlogin.com we got into the site but we couldn't get internet and wirless was disabled. Since we couldn't get it work spectrum connected one of there routers and it worked perfectly. I took the router back to my house to see if I can find a solution . The router only shows the power light as on . I do not have it hooked up to my network. Hope this helps
What is that modem?
Spectrum has many. One of these?
Modems/Routers/Wireless Adapters | Spectrum Support
That is a bad sign. The internet light should also come on.
You won't get internet without connecting it to modem.
I don't know what you mean by "wireless was disabled". Is that in the settings or just that you don't see an LED or a wifi signal?
Have you tried this?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
- fdelmo10Tutor
Thanks for the response. We did do a factory reset . Didn't help .
set up was modem (hitron model e31n2v1 )
set up
Modem to wired router to PC wired
The message was clear no internet // wireless is disable inside of settings on the pc.
I couldnt not enable wifi off the settings tab.
Specturm attached there router and it worked fine,
