warbkhelo
Sep 09, 2022Follower
Nighthawk R7000 won't connect to internet.
My Netgear Nighthawk R7000 won't connect to the internet. It was working fine this morning, had to move some things around, and accidentally bumped the WiFi button (turning it off). Didn't realize ...
Sep 09, 2022Guru - Experienced User
What modem do you have it connected to?
Make sure to power off both the modem and the router for a couple minutes.
Make sure nothing is connected to the modem or the router.
then power the modem on and wait 2 minutes.
Then connect the modem to the router and power the router on.
Wait 2 minutes.
then attempt setup/usage of the router.
