cskuvlesky
Jan 06, 2021Aspirant
Nighthawk R7000 won't connect to one particular website.
I have a R7000 router that I have had for many years of reliable services. I started developing a wp site recently. Suddenly, I can no longer connect to the domain in any manner from any device ...
michaelkenward
Jan 07, 2021Guru - Experienced User
Strange. To complete the picture, the usual questions.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- cskuvleskyJan 07, 2021Aspirant
The firmware is: V1.0.11.106_10.2.100
the Modem is: Cisco DPC3008 with Spectrum ISP
The modem does not have lan ports on the back.
Thank you, Christopehr
- michaelkenwardJan 07, 2021Guru - Experienced User
Modem only. No router section to get in the way.
Not the latest.
R7000 Firmware Version 1.0.11.110 | Answer | NETGEAR Support
