mattand
Oct 30, 2021Tutor
Nighthawk R7000 won't keep iPhones on 5ghz band
Just got a new R7000 Nighthawk to replace the Verizon-supplied Fios router. I'm paying for 200/200, but routinely get 300/300 on most devices, wired and wireless. Overall the router is great and for ...
mattand
Oct 30, 2021Tutor
Hey, Furry,
Thanks for the response. I’m hesitant to try that right now, mainly because I have a Harmony Hub that was a bear to reactivate when I switched the network over to Smart Connect.It is definitely a good idea, though, and I will try it at some point. Thanks for reaching out.
Oct 30, 2021Guru - Experienced User
