stevedude
Mar 22, 2019Aspirant
Nighthawk R7000 won't recognize network devices connected through switches
Nighthawk R7000 Windows 10 Pro
latest firmware update on 3/22/2019 V1.0.9.64_10.2.64
Router recognizes about half of my network. Doesn't recognize switches or devices that would be connected t...
- Jun 01, 2019
Solved. Got a buddy to help me sort it out. The internet provider company had installed not just a gateway to the fiber optic system but a modem router combo as well. I told them that the router part needed to be off as I was using my own. They may or may not have done so but their piece of equipiment was still setting up its own subnet which is where the non-recognition problem lay. Removing that piece of equipment and hooking my router directly to their "gateway" {their term}, which apparently functions as a modem even though they don't call it that, fixed all my problems.
stevedude
Mar 31, 2019Aspirant
Well, guess I'll look at other communities and forums for help. The one response I got was just criticism and not at all helpful.
stevedude
Jun 01, 2019Aspirant
