jnt2112
Jul 05, 2017Aspirant
Nighthawk R7000
I can connect to internet directly by ethernet cable but absolutely nothing will connect thru wifi. It always says incorrect password even though I have done a reset twice and also tried changing the...
- Aug 13, 2017
Hi treball,
It is how NETGEAR routers work. It should be connected to the modem for Internet to work.
netwrks
Jul 05, 2017Master
Did you change the router SSID's, or are you using the default NG SSID's? Are you changing the wifi passphrase, or the router login password?..
jnt2112
Using all default info as far as SSID'S , passphrase and internet wifi password but I did change the router login password
- JamesGLJul 11, 2017NETGEAR Employee Retired
Hi jnt2112,
Try changing the SSID and password of your wireless network.
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi jnt2112,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- netwrksJul 17, 2017Master
Never use default passwords, or passphrases, as you are setting your self up for a possible router / wifi compromise, from the outside world. If anyone in Internet land would use your wireless network, or router, for anything malicious, by law, you are responsible. In this case, ignorance is not bliss. So, be sure to set a strong router login passwod, and a strong wifi passphrase. Don't give out password out to anyone (of course family would need your wifi passphrase). If you do give it out, to other than family, then make sure you change ASAP..
