jnt2112
Jul 05, 2017Aspirant
Nighthawk R7000
I can connect to internet directly by ethernet cable but absolutely nothing will connect thru wifi. It always says incorrect password even though I have done a reset twice and also tried changing the...
- Aug 13, 2017
Hi treball,
It is how NETGEAR routers work. It should be connected to the modem for Internet to work.
jnt2112
Using all default info as far as SSID'S , passphrase and internet wifi password but I did change the router login password
