jnt2112
Jul 05, 2017Aspirant
Nighthawk R7000
I can connect to internet directly by ethernet cable but absolutely nothing will connect thru wifi. It always says incorrect password even though I have done a reset twice and also tried changing the...
- Aug 13, 2017
Hi treball,
It is how NETGEAR routers work. It should be connected to the modem for Internet to work.
treball
Aug 05, 2017Aspirant
hello i'm having the same issues i think..... i've tried setting this thing up more than onces and keep getting the same results... i can connect to my internet with the wired cable after the smart wizard setup, everything is working fine ! but when i disconnect it to set it up in the place i wanna put it to get a stronger signal for my wifi, theirs no signal for internet connection for wifi use at all.... i have to leave it connect to the modem for it to work, and this defeats the whole purpose of having this router.... please let me know if i'm missing some steps or do i have to keep it connected to my modem for this router to work !
JamesGL
Aug 09, 2017NETGEAR Employee Retired
Hi treball,
The router should always be connected to the modem for it to have an internet connection. That is how the setup works.
- treballAug 09, 2017Aspirantoh ok... i thought it was one of those routers where you didnt need to be connected to keep running....
