jnt2112
Jul 05, 2017Aspirant
Nighthawk R7000
I can connect to internet directly by ethernet cable but absolutely nothing will connect thru wifi. It always says incorrect password even though I have done a reset twice and also tried changing the...
- Aug 13, 2017
Hi treball,
It is how NETGEAR routers work. It should be connected to the modem for Internet to work.
treball
Aug 09, 2017Aspirant
oh ok... i thought it was one of those routers where you didnt need to be connected to keep running....
