Jcgreco
Mar 05, 2019Aspirant
Nighthawk R7000
I tried to do the firmware update and it looks like it failed. I can’t access the web portal nor can I update the firmware manually. It gets to about 50% and Fails The router is only eight months old ...
microchip8
Mar 05, 2019Master
michaelkenward
Mar 06, 2019Guru - Experienced User
But first describe the state of the LEDs on the R7000.
- JcgrecoMar 06, 2019AspirantThe power is flashing white and orange. And the cable I’m connected to is white
This is work great thank you
- michaelkenwardMar 07, 2019Guru - Experienced User
Does that mean TFTP fixed it?
If so, it might help others if you accepteds the message from microchip8 as the solution.
- JcgrecoMar 07, 2019AspirantThat is correct it’s fixed
