LJJones
May 15, 2021Aspirant
Nighthawk R7000
My router is about 4 years old. I'v been having trouble with internet provider, but now wifi is not working the lights on the router for the 2.4 and 5 ghz are not lit up. Just wondering how to tell...
LJJones
May 16, 2021Aspirant
It's turned on. Some of the lights are on, just not the ones that indicate that the radio is working. Thank's for the reply. I appreciate it.
wcalifas
May 16, 2021Prodigy
If pressing the wifi button didn't solve it maybe you can just try to do a hard reset by pressing the reset button for 30 seconds with a paper clip. It will be back to factory defaults. Let us know what happens.
