masample
Sep 20, 2021Follower
Nighthawk R7000
Firmware Version V1.0.11.128_10.2.112 When using the web browser on the basic home tab, I see there are 23 attached devices. Selecting the attached devices tab, I only see 10 devices. Anyone hav...
jiceman
Oct 24, 2021Tutor
I am using the same firmware and have the same issue.
jiceman
Oct 24, 2021Tutor
Also, in only see the subset of devices in the Nighthawk app. But, in the old Genie app, it shows many more (maybe all) devices.
- jicemanOct 24, 2021Tutor
Also, if you look at the access controll tab, you may see more devices listed. Maybe a possible work around.
- AugerStNov 13, 2021Aspirant
Hello,
Same issue and I had to reset the R7000 with the reset button on the back of the device (device on, keep it pressed for at least 5s). I think the problem comes from this firmware.
Warning : doing this, you will loose all the settings : router mode, wifi id and password ...
SA.
