Fossil45's avatar
Fossil45
Nighthawk R7000
Just wondering if this router has connection point for VOIP phone. Thanks in advance for any assistance
  • michaelkenward's avatar
    michaelkenward
    Oct 13, 2021
    Fossil45 wrote:
    I have a Netgear Modem/router which has two dedicated phone connections. I just wondered if this router had the same feature.
    No. The R7000 is a router. Your unnamed Netgear modem/router is, as the label suggests, also a modem.
    If it has phone connections that means that it is probably something like the C7100V, which is a "WiFi Cable Modem Router For XFINITY® Internet & Voice".
    If you want to use the R7000, then you can see if your modem/router can do "bridge" (modem only) mode. This is an option on the C7100V.
    You will not find a standalone router with "voice". Netgear also makes modem only devices with voice, such as the CM1150V Voice Cable Modem.
