Fossil45
Oct 11, 2021Aspirant
Nighthawk R7000
Just wondering if this router has connection point for VOIP phone. Thanks in advance for any assistance
- Oct 13, 2021
Fossil45 wrote:
I have a Netgear Modem/router which has two dedicated phone connections. I just wondered if this router had the same feature.
No. The R7000 is a router. Your unnamed Netgear modem/router is, as the label suggests, also a modem.
If it has phone connections that means that it is probably something like the C7100V, which is a "WiFi Cable Modem Router For XFINITY® Internet & Voice".
If you want to use the R7000, then you can see if your modem/router can do "bridge" (modem only) mode. This is an option on the C7100V.
You will not find a standalone router with "voice". Netgear also makes modem only devices with voice, such as the CM1150V Voice Cable Modem.
Fossil45
Oct 13, 2021Aspirant
I am not really on point in these issues. I have a Netgear Modem/router which has two dedicated phone connections. I just wondered if this router had the same feature. Thank you for your reply to my query
michaelkenward
Oct 13, 2021Guru - Experienced User
- Fossil45Oct 13, 2021Aspirant
Thanks so much for your reply. It is so helpful to a no clue person like myself.
Currently I have an Enhanced Hybrid LTE Gateway. Model No: NL1901ACV
At least I now understand that a modem and a router are two different things.
Once again I thank you for your help
Regards
Bill
