Indrajit
Jun 28, 2021Guide
Nighthawk R7000/AC1900 randomly disconnecting
Firmware is updated, it works after rebooting for few hours or a day and disconnects again all the devices although all the indicators are green. Devices shows the WiFi bars active, but can’t open any...
Jun 28, 2021Guru - Experienced User
What actual firmware are you on? (the r7000 is rarely on "the latest")
What modem/gateway are you using?
Since upgrading firmware, has a factory resest and reinstall (not using a backup configuration) been done?
