CarlE_01
Oct 07, 2019Aspirant
NightHawk R7000p - Http uses an insecure authentication procedure
I keep getting notifications from Lenovo and Bitdifender that my network "http uses an insecure authentication procedure" and tells me to update the software. I went checked for router updates and it...
- Oct 09, 2019
CarlE_01 wrote:
Thanks for the feedback, hopefully I can clear it up.
Not really. You have just repeated what we already knew and added a few bits of probably irrelevant detail.
Try this:
Search - NETGEAR Communities – Bitdefender
Follow some of those items and you will see that this has been going on for years.
Bitdefender makes money by scaring people. Perhaps with Halloween coming up we can expect to see more scary stuff around.
In the meantime, you might like to Lenovo security, whatever that is, and Bitdefender and ask them what is going on.
michaelkenward
Oct 08, 2019Guru - Experienced User
CarlE_01 wrote:
I keep getting notifications from Lenovo and Bitdifender that my network "http uses an insecure authentication procedure" and tells me to update the software. I went checked for router updates and it says the router is up to date. Help, please.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
CarlE_01 wrote:
**I ran bitdefender Home Security Scan and it traced the risk back to the router**
They would say that, wouldn't they. This would not be the first false alarm from that source.
- CarlE_01Oct 08, 2019Aspirant
Hardware Version: R7000P
Firmware Version: V1.3.1.64_10.1.36
Thanks for the help, I appreciate it.
About 2-3 months ago, when I bought the router, Lenovo & Bitdefender were not acting up like this.
- antinodeOct 08, 2019Guru
> I keep getting notifications [...]
When you do what, exactly? What's the whole, actual message?
Copy+paste is your friend.> [...] from Lenovo and Bitdifender [...]
"Lenovo"? Really?
> [...] it traced the risk back to the router**
What's the whole, actual message? Copy+paste is your friend.
It's common to get complaints from a web browser when you use the
router's management web site, because the browser is worried about your
sending some user credentials over an unencrypted/insecure link
("http://" instead of "https://"). The easy thing to do is ignore the
warning, and proceed. Presumably, you're talking to your own gizmo on
your own LAN. If someone can overlisten to that traffic, then you're
already in big trouble. From your description, it's not clear what's
emitting these messages which are bothering you, or why.- CarlE_01Oct 08, 2019Aspirant
Issue: Whenever I connect to my home network, I get a pop up from Lenovo security and Bitdefender that my network is unsecure and could have "malicious activity". The issue is recent, it just started happening like a week or two ago. I thought maybe it was the firmware and checked for updates, but it keeps showing that the NightHawk(AC2300, R7000P, V1.3.1.64) firmware is up to date.
Whenever I connect to any other public wi-fi, I just get a warning that the wi-fi is unsecure, and I know thats to be expected because its public wi-fi.I just don't understand why I'm getting a warning on my home network for "malicious activity".
Hopefully you can see the screenshot, Bitdefender is suggesting I upgrade to the latest firmware, but acording to NetGear the router is up to date.
My question then is, what could possibly be sparking up my anti-virus that there is malicious activity on my home-network? Also, the internet/wi-fi keeps dropping, but I've been looking around the forums here, and I think I found a solution for that.
*I disabled the SSID, run a VPN, have an AV (bitdefender), and of course have a WPA2 password for the wi-fi.*
