CarlE_01's avatar
CarlE_01
NightHawk R7000p - Http uses an insecure authentication procedure
I keep getting notifications from Lenovo and Bitdifender that my network "http uses an insecure authentication procedure" and tells me to update the software. I went checked for router updates and it...
  • michaelkenward's avatar
    michaelkenward
    Oct 09, 2019
    CarlE_01 wrote:
    Thanks for the feedback, hopefully I can clear it up.
    Not really. You have just repeated what we already knew and added a few bits of probably irrelevant detail.
    Try this:
    Search - NETGEAR Communities – Bitdefender
    Follow some of those items and you will see that this has been going on for years.
    Bitdefender makes money by scaring people. Perhaps with Halloween coming up we can expect to see more scary stuff around.
    In the meantime, you might like to Lenovo security, whatever that is, and Bitdefender and ask them what is going on.
