dckrol
Oct 16, 2023Aspirant
Nighthawk R7000P- Port forwarding multiple external ports to 1 internal port
I have recently swapped into the Nighthawk R7000P and I am trying to replicate my port forwards that I was using on my previous router that all worked fine. However now that I am trying to set these ...
schumaku
Oct 17, 2023Guru - Experienced User
Please do as advised by the Web UI: Configure either the same port range for WAN and LAN, or tick "Use the same ...".
dckrol
Oct 17, 2023Aspirant
It just doesn’t work if I do that. I know I’m able to do it as I have done it before I just don’t know how to be able to configure it to do so on this router.
