aliaa
May 07, 2022Aspirant
Nighthawk R7000P and Starlink
We recently installed Starlink gen 2 but need to keep our home wireless system for various reasons. My attempts to use our existing Nighthawk R7000P router with the Starlink router in bypass mode wer...
bwilt
May 19, 2022Initiate
I had a similar problem, took all day to fix it. I recently installed a Starlink gen 2 (rectangular antenna) with the ethernet adapter. I bought a R7000 at Best Buy. I tried installation from scratch several times but I became stuck. I was able to access the router configuration at 192.168.1.1 from my browser, but I had no internet connection. I read all the Starlink messages in this forum, but everyone seemed stuck. I tried setting up a static route, I tried various combinations of IP address and gateway, no luck. I finally called the customer support phone number after 5pm my time. The first thing the rep did was ask me to go to the command line and type ipconfig. I clicked on the start button, typed "cmd" in empty space, then run as administrator, and typed in ipconfig. I hadn't used that command in a long time but I immediately knew what was wrong. My gateway was 192.168.1.254 but the router was 192.168.1.1.
The rep didn't need to say anything more. I went into the control panel, Network and sharing center, then "change adapter settings." I double-clicked on the active Ethernet item and opened properties, then "Internet Protocol Version 4". I had originally hard-coded my IP address and gateway, and I could have just changed the gateway IP address, but I took the easy way and clicked the button for "Obtain an IP address automatically". This lets the router's DHCP do all the work. I clicked OK enough times to get out and rebooted the machine. Voila! I had internet. The next couple of hours was spent changing everything on my network to DHCP or at least to a gateway of 192.168.1.1.
I left a good review for the rep.
aliaa
May 19, 2022Aspirant
Thanks for all of this. I haven't yet re-tried connecting SL router and our existing wireless system, but your info may well be very helpful!
