ksNGacct
Jul 09, 2021Guide
Nighthawk R7000P Connecting to only some devices
I've had issues the past month with dropping internet on devices in our home network. This has normally been remedied by rebooting the Nighthawk R7000P router. The past couple days some devices such ...
Jul 09, 2021Guru - Experienced User
what firmware version are you on?
Have you tried a simple factory reset
ksNGacct
Jul 09, 2021Guide
Firmware says it is up to date and lists v1.3.2.134_10.1.66
oddly, I have tried to to the factory reset a few times by depressing the button, holding for 15 seconds and the LED lights patterns don't change and the settings are not returned to defaults.
- plemansJul 09, 2021Guru - Experienced User
you can reset through the browser. login and go to advanced--->administration---->backup settings---->erase
- ksNGacctJul 09, 2021Guide
Thanks for the link to reset the router to factory defaults. I went through the process and the result is pretty much the same. I have some devices (iphone, ipad) that are connecting fine with wireless. I have a desktop that will connect with an ethernet from the router to the desktop, but the wireless won't connect. Also have separate laptop that was getting wireless before the reset but is not now.
Correction: as of now all devices appear to be connected. May have needed some time to cycle the changes? Thanks
