ALFY_NET
Sep 24, 2023Aspirant
Nighthawk R7000P in access mode only accepts 2 devices
Hi,
I have this router configured as "access mode" because I need to access devices connected to this wireless router, my firewall is providing ip addresses through firewall dhcp and 20 IPs are ava...
michaelkenward
Sep 25, 2023Guru - Experienced User
ALFY_NET wrote:
I have this router configured as "access mode" because I need to access devices connected to this wireless router, my firewall is providing ip addresses through firewall dhcp and 20 IPs are available.
What is that "firewall"? These don't usually handle "routering".
In AP mode, the R7000P hands most things over to the router that sits between you and the Internet. What is the modem/ONT/gateway/router or whatever it is that handles the traffic?
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- ALFY_NETSep 25, 2023Aspirant
I have a Cisco ASA in front of the Nighthawk and has dhcp enable with 20 ip addresses available.
- michaelkenwardSep 26, 2023Guru - Experienced User
You may have to explain how that fits into the network.
Netgear's routers are designed to sit behind a modem of some sort or, in AP mode, behind a router.
The circumstances you describe seem to be rare. Anything that has appeared might be here:
Search - NETGEAR Communities – cisco asa
It might also make sense to ask Cisco how you are supposed to attach things to its hardware.
